[postgis-devel] open issues for 1.0.1 ?
Markus Schaber
schabi at logix-tt.com
Mon May 2 04:21:43 PDT 2005
Hi, Strk,
strk at refractions.net wrote:
> Markus, is any JDBC2 change missing here ? If it is please update
> the CHANGES file.
The only jdbc2 changes up to now are adding "eclipsebin" to .cvsignore,
and adding "-target 1.2 -source 1.2" to the javac command line, which
guarantees that the generated class files run on java 1.2 and up even
when they are compiled using jdk 1.5.
I added a small notice to the latter change to the CHANGES.
Markus
