[postgis-devel] open issues for 1.0.1 ?
strk at refractions.net
Mon May 2 09:10:30 PDT 2005
On Mon, May 02, 2005 at 01:21:43PM +0200, Markus Schaber wrote:
> Hi, Strk,
> strk at refractions.net wrote:
> > Markus, is any JDBC2 change missing here ? If it is please update
> > the CHANGES file.
> The only jdbc2 changes up to now are adding "eclipsebin" to .cvsignore,
> and adding "-target 1.2 -source 1.2" to the javac command line, which
> guarantees that the generated class files run on java 1.2 and up even
> when they are compiled using jdk 1.5.
> I added a small notice to the latter change to the CHANGES.
Ported CHANGES to the HEAD branch as well. Thanks.
--strk;
