[postgis-devel] Transform() PROJ4 cache patch
strk at refractions.net strk at refractions.net
Wed Nov 2 02:34:44 PST 2005
1.0 is a bugfix only branch, so this goes in 1.1 (head).
There might be users using transform_geom() to speedup
mapserver operations, I woudn't feel like breaking their
setups.
--strk;
On Wed, Nov 02, 2005 at 09:51:12AM -0000, Mark Cave-Ayland wrote:
> > -----Original Message-----
> > From: postgis-devel-bounces at postgis.refractions.net
> > [mailto:postgis-devel-bounces at postgis.refractions.net] On
> > Behalf Of strk at refractions.net
> > Sent: 02 November 2005 07:43
> > To: 'PostGIS Development Discussion'
> > Subject: Re: [postgis-devel] Transform() PROJ4 cache patch
> > Mark, the new version builds fine on 7.2.1
> > Before continuing with the test would you please take the
> > transform_geom() function back ?
> > It would break back-compatibility if we remove it.
> > Also, please work against the head branch.
> > Later.
> > --strk;
> Hi strk,
> Thanks for testing again. Do you mean 1.1.0CVS HEAD or the pgis_1_0 branch?
> It would be really nice to get this in 1.0.x if we can persuade users to
> upgrade their SQL scripts :)
> Also, do you think it's really worth keeping transform_geom()? I only
> realised it was there while writing this patch since it is an internal API
> and not documented anywhere. Perhaps a quick poll on -users?
> Kind regards,
> Mark.
> WebBased Ltd
> 17 Research Way
> Plymouth
> PL6 8BT
> T: +44 (0)1752 797131
> F: +44 (0)1752 791023
> http://www.webbased.co.uk
> http://www.infomapper.com
> http://www.swtc.co.uk
> This email and any attachments are confidential to the intended recipient
> and may also be privileged. If you are not the intended recipient please
> delete it from your system and notify the sender. You should not copy it or
> use it for any purpose nor disclose or distribute its contents to any other
> person.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
