[postgis-devel] Transform() PROJ4 cache patch
strk at refractions.net strk at refractions.net
Thu Nov 3 01:45:13 PST 2005
Another comment, why use a separate file ?
I think it would make maintainence harder.
--strk;
On Tue, Nov 01, 2005 at 10:34:37PM -0000, Mark Cave-Ayland wrote:
> > -----Original Message-----
> > From: postgis-devel-bounces at postgis.refractions.net
> > [mailto:postgis-devel-bounces at postgis.refractions.net] On
> > Behalf Of Mark Cave-Ayland
> > Sent: 01 November 2005 12:06
> > To: 'PostGIS Development Discussion'
> > Subject: RE: [postgis-devel] Transform() PROJ4 cache patch
> (cut)
> > > Great work Mark.
> > > I tested your code against 7.2.1, but it doesn't compile:
> > > gcc -DUSE_VERSION=72 -DPOSTGIS_LIB_VERSION='"1.1.0CVS"'
> > > -DPOSTGIS_SCRIPTS_VERSION='"0.3.1"'
> > > -DPOSTGIS_BUILD_DATE='"2005-11-01 10:37:45"'
> > > -I/usr/home/strk/extra/proj-4.4.5//include -DUSE_PROJ
> > > -I/pgroot-7.2.1/include/postgresql/server -DAUTOCACHE_BBOX=1
> > > -DUSE_STATS -Wall -g -O2 -fPIC -fexceptions -DUSE_GEOS    -c
> > > -o lwgeom_transform.o lwgeom_transform.c
> > > lwgeom_transform.c:84: warning: excess elements in struct
> > initializer
> > > lwgeom_transform.c:84: warning: (near initialization for
> > > `PROJ4SRSCacheContextMethods')
> > > lwgeom_transform.c:89: warning: excess elements in struct
> > initializer
> > > lwgeom_transform.c:89: warning: (near initialization for
> > > lwgeom_transform.c: In function `AddToPROJ4SRSCache':
> > > lwgeom_transform.c:196: warning: implicit declaration of
> > > function `SPI_execute'
> > > lwgeom_transform.c: In function `transform':
> > > lwgeom_transform.c:493: `MessageContext' undeclared (first
> > > use in this function)
> > > lwgeom_transform.c:493: (Each undeclared identifier is
> > > reported only once
> > > lwgeom_transform.c:493: for each function it appears in.)
> > > --strk;
> Hi strk,
> Please find enclosed a revised version of the patch for testing. I've moved
> all of the caching code into lwgeom_transform_cache.c/h and changed the
> memory context for the cache to be QueryContext, since MessageContext is
> designed to hold information slightly longer than required. I've also added
> code in lwgeom_transform_cache.c to set the correct MemoryContextMethods
> structure depending upon the version of PostgreSQL (although I haven't been
> able to test it against any older versions since all our installations are
> now PostgreSQL 8.0!) and reverted to using the older SPI_exec() instead of
> SPI_execute().
> Kind regards,
> Mark.
> WebBased Ltd
> 17 Research Way
> Plymouth
> PL6 8BT
> T: +44 (0)1752 797131
> F: +44 (0)1752 791023
> http://www.webbased.co.uk
> http://www.infomapper.com
> http://www.swtc.co.uk
> This email and any attachments are confidential to the intended recipient
> and may also be privileged. If you are not the intended recipient please
> delete it from your system and notify the sender. You should not copy it or
> use it for any purpose nor disclose or distribute its contents to any other
> person.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
