[postgis-devel] error with GIST indexes with NULLs
Kevin Neufeld
kneufeld at refractions.net
Wed Dec 20 09:51:02 PST 2006
Thanx Sandro. The fix worked great.
I've committed the change and added a regression test as you suggested.
Cheers,
Kevin
strk at refractions.net wrote:
> On Fri, Dec 15, 2006 at 05:46:28PM +0000, Mark Cave-Ayland wrote:
>> On Fri, 2006-12-15 at 17:00 +0100, strk at refractions.net wrote:
>> Hi strk,
>>> On Fri, Dec 15, 2006 at 07:36:09AM +0000, Mark Cave-Ayland wrote:
>>>> Confirmed. I've had a quick look at this with a debugger, and it appears
>>>> that the culprit is BOX2D_union calling PG_RETURN_NULL, which causes
>>>> DirectFunctionCall2 to error out in fmgr.c.
>>> BOX2D_union is likely *always* returning NULL. We're talking about 459
>>> success and 1 failure ...
>> AIUI the GiST penalty clause is called to determine into which subtree
>> it is the least expensive to insert into - so my guess is that the
>> insertion is falling over just after the first page split, but I don't
>> have enough time to investigate at the moment :(
> I don't have 8.2 around, anyway the attached patch avoids calling DirectFunctionCall2
> if both inputs are NULL. Kevin, can you check if it fixes your issue ?
> Also, could you add a testcase for this in the SVN repository ? We already have
> a regress_lots_of_points.sql file, we should add a regress_lots_of_null.sql and
> use it in a similar way from regress_index.sql.
> --strk;
> Index: lwgeom/lwgeom_gist.c
> --- lwgeom/lwgeom_gist.c (revision 2557)
> +++ lwgeom/lwgeom_gist.c (working copy)
> @@ -959,14 +959,25 @@
> #endif
> - ud = DirectFunctionCall2(BOX2D_union, origentry->key, newentry->key);
> - /*ud = BOX2D_union(origentry->key, newentry->key); */
> - tmp1 = size_box2d_double(ud);
> - if (DatumGetPointer(ud) != NULL)
> - pfree(DatumGetPointer(ud));
> + if (DatumGetPointer(origentry->key) == NULL && DatumGetPointer(newentry->key) == NULL)
> +#ifdef PGIS_DEBUG_GIST6
> + elog(NOTICE,"GIST: LWGEOM_gist_penalty called with both inputs NULL");
> +#endif
> + *result = 0;
> + else
> - *result = tmp1 - size_box2d_double(origentry->key);
> + ud = DirectFunctionCall2(BOX2D_union, origentry->key, newentry->key);
> + /*ud = BOX2D_union(origentry->key, newentry->key); */
> + tmp1 = size_box2d_double(ud);
> + if (DatumGetPointer(ud) != NULL)
> + pfree(DatumGetPointer(ud));
> + *result = tmp1 - size_box2d_double(origentry->key);
> elog(NOTICE,"GIST: LWGEOM_gist_penalty called and returning %.15g", *result);
> #endif
