AW: [postgis-devel] could not load library /usr/lib/postgresl/lib lwgeom.so.1.1
BIBIS, Bohnebeck, Uta
bohnebeck at ttz-Bremerhaven.de
Wed Feb 8 05:00:12 PST 2006
> It looks like you compiled postgis against the wrong set of PostgreSQL
headers, can this be the case ?
May be.
I'm not a Unix/Linux profi and I strictly followed the installation
instructions (short version)
of PostgreSQL and then of PostGIS.
> Last lines of ./configure should tell you what pg_config you're using.
> pg_config --includedir-server is what's used to find postgres.h
After running ./configure I got the following output:
SUMMARY
HOST_OS: linux-gnu
PGSQL: /usr/bin/pg_config
ICONV: 1
PORTNAME: linux
PREFIX: /usr
EPREFIX: ${prefix}
DOC: /usr/share/doc/packages/postgresql/contrib
DATA: /usr/share/pgsql/contrib
MAN: /usr/share/man
BIN: /usr/bin
EXT: /usr/lib/postgresql (\$$libdir)
-----Ursprüngliche Nachricht-----
Von: strk at refractions.net [mailto:strk at refractions.net]
Gesendet: Mittwoch, 8. Februar 2006 13:43
An: 'postgis-devel at postgis.refractions.net'
Betreff: Re: [postgis-devel] could not load library
/usr/lib/postgresl/liblwgeom.so.1.1
of PostgreSQL headers, can this be the case ?
pg_config you're using. pg_config --includedir-server
--strk;
On Wed, Feb 08, 2006 at 01:39:43PM +0100, BIBIS, Bohnebeck, Uta wrote:
> Hello,
> I have installed postgresql (version 8.1.2) and are now trying to install
> postgis (version 1.1.1) on a linux machine
> and receive the following error message:
> contrib/postgis-1.1.1> psql -U postgres -d test -f lwpostgis.sql
> BEGIN
> psql:lwpostgis.sql:45: NOTICE: type "histogram2d" is not yet defined
> psql:lwpostgis.sql:45: ERROR: could not access file
> "$libdir/liblwgeom.so.1.1": No such file or directory
> psql:lwpostgis.sql:50: ERROR: current transaction is aborted, commands
> ignored until end of transaction block
> After modifying the variable $libdir to the path /usr/lib/postgresql
> the file was found but nethertheless the library is not loaded.
> BEGIN
> psql:lwpostgis.sql:45: ERROR: could not load library
> "/usr/lib/postgresql/liblwgeom.so.1.1":
> /usr/lib/postgresql/liblwgeom.so.1.1: undefined symbol: nth
> Any ideas to solve this problems?
> Best regards,
> Uta
> postgis-devel mailing list
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
| Fight against software patents in EU! |
| www.ffii.org www.nosoftwarepatents.org |
