AW: [postgis-devel] could not load library /usr/lib/postgresl/lib lwgeom.so.1.1
TECHER David
davidtecher at yahoo.fr
Wed Feb 8 06:05:49 PST 2006
Hi
Is /usr/lib/postgresql in your file /etc/ld.so.conf ???
If it is not the case, as root do
echo /usr/lib/postgresql >> /etc/ld.so.conf
ldconfig -v
su postgres
dropdb yourdb
createdb yourdb
createlang plpgsql yourdb
psql -d yourdb -f $(find $(pg_config --bindir)/.. | grep lwpostgis.sql)
spatial_ref_sys.sql)
BIBIS, Bohnebeck, Uta a écrit :
>>It looks like you compiled postgis against the wrong set of PostgreSQL
>headers, can this be the case ?
>May be.
>I'm not a Unix/Linux profi and I strictly followed the installation
>instructions (short version)
>of PostgreSQL and then of PostGIS.
>>Last lines of ./configure should tell you what pg_config you're using.
>>pg_config --includedir-server is what's used to find postgres.h
>After running ./configure I got the following output:
>SUMMARY
> HOST_OS: linux-gnu
> PGSQL: /usr/bin/pg_config
> ICONV: 1
> PORTNAME: linux
> PREFIX: /usr
> EPREFIX: ${prefix}
> DOC: /usr/share/doc/packages/postgresql/contrib
> DATA: /usr/share/pgsql/contrib
> MAN: /usr/share/man
> BIN: /usr/bin
> EXT: /usr/lib/postgresql (\$$libdir)
>-----Ursprüngliche Nachricht-----
>Von: strk at refractions.net [mailto:strk at refractions.net]
>Gesendet: Mittwoch, 8. Februar 2006 13:43
>An: 'postgis-devel at postgis.refractions.net'
>Betreff: Re: [postgis-devel] could not load library
>/usr/lib/postgresl/liblwgeom.so.1.1
>of PostgreSQL headers, can this be the case ?
>pg_config you're using. pg_config --includedir-server
>--strk;
>On Wed, Feb 08, 2006 at 01:39:43PM +0100, BIBIS, Bohnebeck, Uta wrote:
>>Hello,
>>I have installed postgresql (version 8.1.2) and are now trying to install
>>postgis (version 1.1.1) on a linux machine
>>and receive the following error message:
>>contrib/postgis-1.1.1> psql -U postgres -d test -f lwpostgis.sql
>>BEGIN
>>psql:lwpostgis.sql:45: NOTICE: type "histogram2d" is not yet defined
>>psql:lwpostgis.sql:45: ERROR: could not access file
>>"$libdir/liblwgeom.so.1.1": No such file or directory
>>psql:lwpostgis.sql:50: ERROR: current transaction is aborted, commands
>>ignored until end of transaction block
>>After modifying the variable $libdir to the path /usr/lib/postgresql
>>the file was found but nethertheless the library is not loaded.
>>BEGIN
>>psql:lwpostgis.sql:45: ERROR: could not load library
>>"/usr/lib/postgresql/liblwgeom.so.1.1":
>>/usr/lib/postgresql/liblwgeom.so.1.1: undefined symbol: nth
>>Any ideas to solve this problems?
>>Best regards,
>>Uta
>>_______________________________________________
>>postgis-devel mailing list
>>http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20060208/4c77e13f/attachment.html>
