[postgis-devel] Truly_inside(geometry, geometry)
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Thu Feb 23 02:34:05 PST 2006
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On
> Behalf Of Steve Way
> Sent: 23 February 2006 09:27
> To: PostGIS Development Discussion
> Subject: RE: [postgis-devel] Truly_inside(geometry, geometry)
> Hi There,
> I tried the functions you specified, which meant I had to
> install GEOS.
> So I installed the GEOS library, the compiled PostGIS with
> GEOS support, and didn't receive any erros, however, my
> selection is still not being highlighted like before using
> the truly_inside function.
> Is there any other functions that would work exactly like
> truly_inside?
> I cant believe a function which was working perfectly well
> was just "aborted"
> You help guys would be much appreciated
> Steve W
Hi Steve,
Did you reload the lwpostgis.sql file into your database after you
recompiled with GEOS? What does SELECT postgis_full_version() give you? Does
it mention GEOS?
Also if you are using Mapserver, then it is worth making a deliberate error
in your DATA statement so that Mapserver generates an error. You can then
copy the SQL generated from Mapserver into a psql session and experiment
further there.
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
http://www.webbased.co.uk
http://www.infomapper.com
http://www.swtc.co.uk
This email and any attachments are confidential to the intended recipient
and may also be privileged. If you are not the intended recipient please
delete it from your system and notify the sender. You should not copy it or
use it for any purpose nor disclose or distribute its contents to any other
person.
