[postgis-devel] JDBC: Setting/Getting JTS-geometries using bind-vars
Aron Olsen
ArO at CARLBRO.DK
Fri Jan 6 02:21:06 PST 2006
Hi there,
I'm a newcomer to Postgresql / PostGis but have experience from Oracle.
I was looking for a way to get JTS-geoms from ResultSets and to set
JTS-geoms in PreparedStatements using bind-vars, but what I found was not
very usefull. Usually everybody seems to use WKT, which requires a special
SQL-syntax. This was not acceptable to me.
Using the "plain" JDBC-driver I took a look at what I got from getObject(
int n ) on a geometry column. It was a PGobject.
Then I took a look at the contents of PGobject.getValue(), and found that
it's a hex-encoded WKB.
Then I realized that I could construct a PGobject using:
po.setType( "geometry");
po.setValue( hexedBinaryString );
and that I could bind it to a statement using setObject( 1, po );
By reverse-engineering the BinaryParser and BinaryWriters into
JTSBinaryParser and JTSBinaryWriter I was able to get and set JTS more or
less directly, on a "plain" JDBC-driver.
Heres sample code for getting and setting:
// Getting:
PreparedStatement stmt1 = connection.prepareStatement("select geom from xxx
where id=25");
ResultSet rs = stmt1.executeQuery();
rs.next();
PGobject po = rs.getObject(1);
JTSBinaryParser jbp = new JTSBinaryParser();
Geometry g = jbp.parse( s0 );
// Setting
JTSBinaryWriter jbw = new JTSBinaryWriter();
PGobject newPo = new PGobject();
newPo.setType("geometry");
newPo.setValue( jbw.writeHexed( g ) );
PreparedStatement stmt2 = connection.prepareStatement("update xxx set geom=?
where id=25");
stmt2.setObject( 1, newPo );
stmt2.executeUpdate();
What a newcomer like me doesn't know is whether this scheme holds for all
postgresql/postgis implementations/versions. Maybe somebody can give me a
hint here ? :)
If anybody would like the source-code for JTSBinaryParser and -Writer I'd be
more than happy to post the code somewhere.
Thanks.
Aron.
