[postgis-devel] A Note for the PostGIS Manual
Carl Anderson
carl.anderson at vadose.org
Sun Jul 9 19:54:40 PDT 2006
This is not a bug (but looks like one at a casual glance)
Users, utilizing statements using the SQL syntax
select the geom from A
union
select the geom from B;
may not get what they expect if geometries in <A> and <B> have the same
bounding boxes but have different shapes.
The SQL UNION syntax uses the bounding box function geometry_eq to
equate geometries.
Without thinking about this issue I had believed that the SQL UNION
syntax used geometry_same to equate geometries.
A bit of background
I was working with US Census TIGER data and was looking for lines
bounding cities.
While tracing down incomplete bounding shapes I (eventually) guessed
this as the cause of my problem.
Somewhere in the PostGIS manual this needs to be memorialized.
For clarity
Select asewkt( shape) from
( select geometry('LINESTRING(1 1,5 6,10 10)') as shape
UNION
select geometry('LINESTRING(1 1,10 10)') as shape
) as a;
returns one tuple ( the bounding boxes are the same)
( select geometry('LINESTRING(1 1,5 11,10 10)') as shape
UNION
) as a;
returns two tuples as ( the bounding boxes are not the same)
C.
