[postgis-devel] A Note for the PostGIS Manual
strk at refractions.net
Thu Jul 20 16:06:16 PDT 2006
Just to complete the picture: the SQL UNION syntax, like the
DISTINCT, GROUP BY and ORDER BY ones, use the btree operators
class.
For PostGIS, the btree opclass has been implemented using
bbox-based operations, but it is not necessarily the right
thing. I think it's not documented for specifically this reason.
A wider discussion might bring to a change in this behaviour
(I don't think anyone relies on that syntax on geometries)
--strk;
On Sun, Jul 09, 2006 at 10:54:40PM -0400, Carl Anderson wrote:
> This is not a bug (but looks like one at a casual glance)
> Users, utilizing statements using the SQL syntax
> select the geom from A
> union
> select the geom from B;
> may not get what they expect if geometries in <A> and <B> have the same
> bounding boxes but have different shapes.
> The SQL UNION syntax uses the bounding box function geometry_eq to
> equate geometries.
> Without thinking about this issue I had believed that the SQL UNION
> syntax used geometry_same to equate geometries.
> A bit of background
> I was working with US Census TIGER data and was looking for lines
> bounding cities.
> While tracing down incomplete bounding shapes I (eventually) guessed
> this as the cause of my problem.
> Somewhere in the PostGIS manual this needs to be memorialized.
> For clarity
> Select asewkt( shape) from
> ( select geometry('LINESTRING(1 1,5 6,10 10)') as shape
> UNION
> select geometry('LINESTRING(1 1,10 10)') as shape
> ) as a;
> returns one tuple ( the bounding boxes are the same)
> ( select geometry('LINESTRING(1 1,5 11,10 10)') as shape
> UNION
> ) as a;
> returns two tuples as ( the bounding boxes are not the same)
> C.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
/"\ ASCII Ribbon Campaign
\ / Respect for low technology.
X Keep e-mail messages readable by any computer system.
/ \ Keep it ASCII.
