[postgis-devel] loader/dumper tests support
Michael Fuhr
mike at fuhr.org
Fri Jun 16 08:55:13 PDT 2006
On Fri, Jun 16, 2006 at 04:29:03PM +0100, Mark Cave-Ayland wrote:
> I've just compiled and run the regression tests from the latest
> postgis-cvs.tar.gz, and all of the tests pass under Win32. Do you think it
> is time for another release to resolve this and the nasty distance()
> function bug? Or should we wait for the SVN upgrade first? ;)
Solaris and FreeBSD both have trouble with the new regression tests.
Function definitions should be
fail ()
instead of
function fail ()
Using the latter style gives syntax errors on both FreeBSD and
Solaris:
./run_test: syntax error at line 47: `(' unexpected
Echo without linefeed is different on various platforms. PostgreSQL's
regression tests do the following:
if echo '\c' | grep c >/dev/null 2>&1; then
ECHO_N='echo -n'
ECHO_C=''
else
ECHO_N='echo'
ECHO_C='\c'
fi
Then, to echo text without a linefeed:
$ECHO_N "something... $ECHO_C"
I'd suggest doing the same, else some platforms give output like
the following with "echo -ne":
-ne loader/mlines2d
.............. ok
-ne loader/mlines3dz
.............. ok
After the function definition and echo fixes, Solaris has yet more
errors:
loader/mlines2d.../run_test: !: not found
The problem is lines like this:
if ! run_simple_test ${TEST}.sql ${TEST}-wkb.expected "wkb insert"; then
return 1
fi
Apparently /bin/sh on Solaris doesn't recognize "!". One way to
handle this is to do nothing for the true condition; I'll have to
do more research to see if there's a better way.
if run_simple_test ${TEST}.sql ${TEST}-wkb.expected "wkb insert"; then
else
return 1
fi
With all of the above changes, Solaris/sparc fails the mlines tests:
loader/mlines2d... failed (wkb insert: diff expected obtained: /tmp/pgis_reg_2180/test_1_diff)
loader/mlines3dz... failed (wkb insert: diff expected obtained: /tmp/pgis_reg_2180/test_2_diff)
loader/mlines3dm... failed (wkb insert: diff expected obtained: /tmp/pgis_reg_2180/test_3_diff)
loader/mlines4d... failed (wkb insert: diff expected obtained: /tmp/pgis_reg_2180/test_4_diff)
I've attached one of the diffs -- is it a byte order problem?
Michael Fuhr
1,2c1,2
< 1|1|01050000000200000001020000000200000000000000000000000000000000000000000000000000F03F000000000000F03F0102000000020000000000000000000840000000000000084000000000000010400000000000001040
< 2|2|01050000000300000001020000000200000000000000000000000000000000000000000000000000F03F000000000000F03F0102000000020000000000000000000840000000000000084000000000000010400000000000001040010200000003000000000000000000244000000000000024400000000000001440000000000000144000000000000008400000000000000840
> 1|1|000000000500000002000000000200000002000000000000000000000000000000003FF00000000000003FF00000000000000000000002000000024008000000000000400800000000000040100000000000004010000000000000
> 2|2|000000000500000003000000000200000002000000000000000000000000000000003FF00000000000003FF00000000000000000000002000000024008000000000000400800000000000040100000000000004010000000000000000000000200000003402400000000000040240000000000004014000000000000401400000000000040080000000000004008000000000000
