[postgis-devel] loader/dumper tests support
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Fri Jun 16 08:29:03 PDT 2006
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-
> bounces at postgis.refractions.net] On Behalf Of strk
> Sent: 16 June 2006 15:19
> To: Michael Fuhr
> Cc: postgis-devel at postgis.refractions.net
> Subject: [postgis-devel] loader/dumper tests support
> I've extended the regress/run_test script
> to handle test for loader/dumper.
> There's a README file under regress/loader that
> explains how does the test work. Currently only
> MULTILINE tests are provided for all dimensions.
> Michael: could you give  the new code a try under Solaris ?
> --strk;
Hi strk,
I've just compiled and run the regression tests from the latest
postgis-cvs.tar.gz, and all of the tests pass under Win32. Do you think it
is time for another release to resolve this and the nasty distance()
function bug? Or should we wait for the SVN upgrade first? ;)
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
http://www.webbased.co.uk
http://www.infomapper.com
http://www.swtc.co.uk
This email and any attachments are confidential to the intended recipient
and may also be privileged. If you are not the intended recipient please
delete it from your system and notify the sender. You should not copy it or
use it for any purpose nor disclose or distribute its contents to any other
person.
