[postgis-devel] Help with GPS Coord in PostGIS
TECHER David
davidtecher at yahoo.fr
Thu May 11 11:58:44 PDT 2006
Hi All
I have a project where I need to import a GPS File (a simple txt file)
which contains think like:
Fahrer A,133840.00,5407.4270,N,01038.0983,E,1,07,1.26,00036,M,045,M,,,44
Fahrer A,133850.00,5407.4266,N,01038.0988,E,1,07,1.26,00033,M,045,M,,,4C
Fahrer A,133900.00,5407.4265,N,01038.0989,E,1,07,1.27,00032,M,045,M,,,4A
Fahrer A,133910.00,5407.4265,N,01038.0989,E,1,07,1.27,00032,M,045,M,,,4B
Fahrer A,133920.00,5407.4265,N,01038.0989,E,1,07,1.27,00031,M,045,M,,,4B
Fahrer A,134500.00,5407.4274,N,01038.0978,E,1,07,1.31,00037,M,045,M,,,4D
into a postgis table
CREATE TABLE gps_coord(
"FAHRER" text ,
"UTC" text ,
latitude double precision ,
"N/S" text ,
longitude double precision ,
"E/W" text ,
"QUALITY" text ,
"#SATELLITES" text ,
"HDOP" text ,
"ANTENNA ALTITUDE" text ,
"M" text ,
"GEO SEPERATION" text ,
"M " text ,
"QUALITDATA" text ,
"DRS ID" text ,
"CHECKSUM" text
then
longitude and latitude are in
degrees/minutes
select addgeometrycolumn('gps_coord','the_geom',4326,'POINT',2);
First of all I'm not really sure for the srid to use with 4326
I have the formula in order to have the
update gps_coord set
the_geom=geometryfromtext('POINT('||(latitude/100)::int+(latitude-5400)/60||'
'||(longitude/100)::int+(longitude-1000)/60||')',4326) ;
select x(the_geom),y(the_geom) from gps_coord limit 6;
x | y
54.1237833333333 | 10.6349716666667
54.1237766666667 | 10.63498
54.123775 | 10.6349816666667
54.12379 | 10.6349633333333
What I want to know is that did I am doing something wrong? A mistake?
With MapServer I got nothing on my picture...
Thanks for help
# DEBUT DE LA MAPFILE
MAP
# EXTENT 10.5956216 54.0569046 10.8584151 54.1410554
#EXTENT 54.0659713745117 10.6110792160034 54.1319885253906 11.8429574966431
EXTENT 10.6110792160034 54.0659713745117 11.8429574966431 54.1319885253906
FONTSET "../etc/fonts.txt"
IMAGECOLOR 125 125 125
IMAGETYPE png
SYMBOLSET "../etc/symbols.sym"
SIZE 680 371
UNITS DD
STATUS ON
NAME "testgis"
# - symbole dash -
SYMBOL
NAME "dash"
TYPE ELLIPSE
POINTS 1 1 END
FILLED TRUE
STYLE 10 5 5 10 END
END
# - symbole line-vertical -
SYMBOL
NAME "line-vertical"
TYPE vector
POINTS
0.5 0
0.5 1
END
END
# - symbole line-horizontal -
SYMBOL
NAME "line-horizontal"
TYPE vector
POINTS
0 0.5
1 0.5
END
END
QUERYMAP
COLOR 255 255 0
SIZE -1 -1
STATUS OFF
STYLE HILITE
END
# - WEB -
WEB
IMAGEPATH "/var/www/tutorial/tutorial/tmp/"
IMAGEURL "/tutorial/tutorial/tmp/"
METADATA
END
QUERYFORMAT text/html
END
# MakeLine() -
LAYER
CONNECTION "user=david dbname=testgis host=localhost"
CONNECTIONTYPE POSTGIS
DATA "makeline from (select makeline(the_geom),1 as gid from
gps_coord) as foo USING UNIQUE gid USING SRID=4326"
# LABELITEM "gid"
METADATA
END
NAME "buildings"
SIZEUNITS PIXELS
STATUS ON
TOLERANCE 0
TOLERANCEUNITS PIXELS
TYPE LINE
CLASS
METADATA
END
STYLE
ANGLE 360
OUTLINECOLOR 80 80 80
SIZE 10
SYMBOL "circle"
END
END
END
# FIN DE LA MAPFILE
END
___________________________________________________________________________
Yahoo! Mail réinvente le mail ! Découvrez le nouveau Yahoo! Mail et son interface révolutionnaire.
http://fr.mail.yahoo.com
