[postgis-devel] Win32 crashes with PostGIS 1.1.4 / PostgreSQL 8.2 -- solved
strk at refractions.net
Fri Oct 13 02:55:27 PDT 2006
On Fri, Oct 13, 2006 at 11:11:52AM +0200, Markus Schaber wrote:
> Hi, Strk,
> strk at refractions.net wrote:
> >> And, please, double-check all version settings in all places :-)
> > Is the procedure described in HOWTO_RELEASE incomplete ?
> Well, at least it seems inaccurate. It talks about REL_*_VERSION,
> whereas the Version.config file currently contains SO_*_VERSION and
> JDBC_*_VERSION, and used to contain script versions AFAIR.
Refraction's SVN is currently having problem so I can't fix that.
Anyway, do you feel like adding JDBC versioning info too ?
--strk;
