[postgis-devel] Win32 crashes with PostGIS 1.1.4 / PostgreSQL	8.2	-- solved
    strk at refractions.net
    Fri Oct 13 03:58:51 PDT 2006
On Fri, Oct 13, 2006 at 12:46:30PM +0200, Markus Schaber wrote:
> What do you think about the attached formulation for HOWTO_RELEASE?
No attachment... ?
> Btw, AFAICS the loader/dumper currently don't include that version info
> altogether, they only contain the SVN version. Should we add a UTIL_* here?
loader/dumper show RCSId when called w/out args, that'd help.
> It might make sense to change Version.config to contain only the
> REL_*_VERSION variables, and use them everywhere. There's a low risk
> that we'll have users upgrade more parts then necessary, e. G. if the
> loader and the jdbc don't change in a minor release. But as we won't
> have independent releases of those subprojects, we confuse users even
> more when we release a PostGIS 1.1.9 that contains a jdbc_1.1.8.jar and
> a shp2gpsql version 4711.
Yes, I've been thinknig about this too. Sounds much easier :)
> But, IMHO, this is to be fixed after getting 1.1.4 out, the users are
> waiting for the fixes. :-)
Developers are waiting for the SVN  ;-)
BTW, I see no critical fixes advertised in the CHANGES file, what did I miss ?
--strk;
