[postgis-devel] Re: [JDBC] "Hanging Connection" blocks access to table (JBossMQ)
Markus Schaber
schabi at logix-tt.com
Fri Oct 13 08:31:02 PDT 2006
Hi, Tom,
Tom Lane wrote:
>> Is there any possibility that we make a backend realize this SIGIO (or
>> whatever it gets) when the connection is closed?
> I don't think it'd be a net win to add cycles to every query to check
> the connection every so often.
The SIGIO could set a flag variable via the interrupt handler, and then
the backend could check that variable in a few, selected places. This
should keep the overhead pretty low. And when the connection is low,
there really is no point in continuing to work on the current query.
>> The same is for very long running C-Code functions (like PostGIS
>> geomUnion() on geometries with millions of vertices), those also tend to
>> block the backend for long times, without any possibility to kill it
>> except SIGKILL.
> That's the fault of the C code ... it should be doing
> CHECK_FOR_INTERRUPTS periodically in any long-running loops.
The problem is that most of those long-running functions are in
3rd-party libs like GEOS and ProJ, which are basically only wrapped by
PostGIS, so it won't be easy to sprinkle them with CHECK_FOR_INTERRUPTS.
I suspect that plR might suffer from the same problem.
So we'll have to live with this.
Thanks,
Markus
Markus Schaber | Logical Tracking&Tracing International AG
Dipl. Inf. | Software Development GIS
Fight against software patents in Europe! www.ffii.org
www.nosoftwarepatents.org
