[postgis-devel] Moving towards a 1.2.2 release?
Mark Cave-Ayland
mark.cave-ayland at ilande.co.uk
Fri Jun 1 11:15:45 PDT 2007
On Fri, 2007-06-01 at 08:30 -0700, Mark Leslie wrote:
> > 3. Michael Fuhr's test case:
> > http://postgis.refractions.net/pipermail/postgis-users/2007-May/015809.html
> I'll look at this today.
Excellent :D
> > 4. Issue with regression tests for sql-mm on different platforms:
> > http://postgis.refractions.net/pipermail/postgis-devel/2007-May/002567.html
> I've been rewriting tests to snap results to as 1e-8 grid when I've
> found these errors. It looks like that grid could get considerably
> small if needed.
Ah so wrapping the output in SnapToGrid() is the solution... Let us know
how you get on, and hopefully Michael will be able to test the result on
several different platforms to ensure everything is working ok.
Kind regards,
Mark.
ILande - Open Source Consultancy
http://www.ilande.co.uk
