[postgis-devel] Moving towards a 1.2.2 release?
Mark Cave-Ayland mark.cave-ayland at ilande.co.uk
Fri Jun 1 11:57:29 PDT 2007
On Fri, 2007-06-01 at 14:21 +0100, Mark Cave-Ayland wrote:
> AFAICT the following issues remain before we can release 1.2.2:
> 1. template_gis - the whole thing needs to be revisited...
> 2. Bug #148 - shp2pgsql/unicode points
> 3. Michael Fuhr's test case:
> http://postgis.refractions.net/pipermail/postgis-users/2007-May/015809.html
> 4. Issue with regression tests for sql-mm on different platforms:
> http://postgis.refractions.net/pipermail/postgis-devel/2007-May/002567.html
Oooh I've just remembered one other thing  - Markus, did you ever look
at building the JDBC driver using ant rather than a Makefile?
Kind regards,
Mark.
ILande - Open Source Consultancy
http://www.ilande.co.uk
