[postgis-devel] Re: [postgis-users] installation problem
vamsee movva
vamseejump at gmail.com
Thu May 10 09:12:16 PDT 2007
Hi mark
i executed
createlang plpgsql test
Then
psql -d test -f lwpostgis.sql
I don't know why it is happening like this.
Thanks for your time.
On 5/10/07, Mark Cave-Ayland <mark.cave-ayland at ilande.co.uk> wrote:
> On Thu, 2007-05-10 at 11:59 -0400, vamsee movva wrote:
> > Hi Mark
> > I removed templategis from the above mentioned placed.
> > Then i executed make and make install
> > Then i tried to executed psql -d test -f lwpostgis.sql
> > It gave me lot of errors like
> > psql:lwpostgis.sql:3875: ERROR: current transaction is aborted,
> > commands ignored until end of transaction block
> > ERROR: current transaction is aborted, commands ignored until end of
> > transaction block
> > STATEMENT: CREATE OR REPLACE FUNCTION ST_PolyFromText(text, int4)
> > RETURNS geometry
> > AS '
> > SELECT CASE WHEN geometrytype(GeomFromText($1, $2)) =
> > ''POLYGON''
> > THEN GeomFromText($1, $2)
> > ELSE NULL END
> > LANGUAGE 'SQL' IMMUTABLE STRICT;
> > Thanks for your help
> OK that's looking better... PostgreSQL outputs one ERROR per statement,
> so you'll need to scroll back up your terminal to see what the first
> ERROR statement was. My first guess is that you didn't install PL/PGSQL
> according to http://postgis.refractions.net/docs/ch02.html#PGInstall:
> e.g. you need to do:
> psql -d test -f spatial_ref_sys.sql
> Kind regards,
> Mark.
> ILande - Open Source Consultancy
> http://www.ilande.co.uk
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20070510/ec8062fd/attachment.html>
