[postgis-devel] PATCH: Test PostgreSQL 8.3 patch for PostGIS
Mark Cave-Ayland mark.cave-ayland at ilande.co.uk
Mon May 28 07:44:52 PDT 2007
On Sat, 2007-05-26 at 20:11 -0600, Michael Fuhr wrote:
> On Mon, May 21, 2007 at 05:44:41PM +0100, Mark Cave-Ayland wrote:
> > Well here it is - I finally have a patch against SVN HEAD that passes
> > all regression tests.
> I've tested the patch against PostgreSQL 8.3devel on the following
> systems and all regression tests passed:
> Solaris 9   sparc 32-bit
> Solaris 9   sparc 64-bit
> FreeBSD 6.2 x86   32-bit
> RHEL AS 4   x86   64-bit
Thanks Michael!
So now the question is: should the changes be committed? My current
thinking is that if there are any outstanding issues then they would
only appear with 8.3 - any places in the code I may have missed would
still work fine under older versions of PostgreSQL, but then the
regression tests should find the obvious places.
Anyone else have any feelings about this?
Kind regards,
Mark.
ILande - Open Source Consultancy
http://www.ilande.co.uk
