[postgis-devel] Gist index not used with Multipolygons
Mark Leslie
mark.leslie at lisasoft.com
Thu Oct 11 17:38:19 PDT 2007
It may be as simple as having more polygons than multipolygons. I don't
have a complete understanding of PostgreSQLs optimizer, but if it
decides that there are few enough entries in the table that a sequence
scan will be faster, it will take that approach. Try running the query
on another table built using the multi(polygon) command. This will
produce a multipolygon for each polygon, and should result in the same
execution plan.
Mark Leslie
James DeMichele wrote:
> I have created 2 tables, one with a POLYGON geometry column, and one
> with a MULTIPOLYGON geometry column. They both have the same data,
> meaning that the POLYGON table has simple POLYGONs and the MULTIPOLYGON
> table has the collect(polygon) grouped by an id. Here are the 2 table
> structures:
> CREATE TABLE state_shapes
> (state_shape_id bigserial NOT NULL,
> state_id bigint NOT NULL);
> SELECT
> AddGeometryColumn('','state_shapes','polygon','4326','POLYGON',2);
> CREATE INDEX state_poly_idx ON state_shapes USING gist (polygon);
> CREATE TABLE state_shapes_2
> SELECT
> AddGeometryColumn('','state_shapes_2','polygon','4326','MULTIPOLYGON',2)
> CREATE INDEX state_poly_idx_2 ON state_shapes_2 USING gist (polygon);
> Then, I run a VACUUM ANALYZE on both of these tables. Unfortunately, now
> when I run a query against these tables, ONLY the table with the POLYGON
> geometry type is using the Gist Index:
> FOR STATE_SHAPES:
> explain analyze
> SELECT s.name, ss.polygon
> FROM states s, state_shapes ss
> WHERE s.state_id = ss.state_id
> AND ss.polygon && setsrid('BOX3D(-152.495155 57.894353, -152.295155
> 57.694353)'::box3d, 4326)
> AND within(GeomFromText( 'POINT(-152.395155 57.794353)', 4326),
> ss.polygon);
> -[ RECORD 1
> QUERY PLAN | Hash Join (cost=8.28..11.12 rows=1 width=66618) (actual
> time=1.365..1.418 rows=1 loops=1)
> -[ RECORD 2
> QUERY PLAN | Hash Cond: (s.state_id = ss.state_id)
> -[ RECORD 3
> QUERY PLAN | -> Seq Scan on states s (cost=0.00..2.60 rows=60
> width=21) (actual time=0.008..0.039 rows=60 loops=1)
> -[ RECORD 4
> QUERY PLAN | -> Hash (cost=8.27..8.27 rows=1 width=66613) (actual
> time=1.343..1.343 rows=1 loops=1)
> -[ RECORD 5
> QUERY PLAN | -> Index Scan using state_poly_idx on state_shapes
> ss (cost=0.00..8.27 rows=1 width=66613) (actual time=1.33
> 2..1.340 rows=1 loops=1)
> -[ RECORD 6
> QUERY PLAN | Index Cond: (polygon &&
> '0103000020E610000001000000050000006E6E4C4FD80F63C09370218FE0D84C406E6E4
> C4FD80F6
> 3C0000000207AF24C400708E6E8710963C0000000207AF24C400708E6E8710963C093702
> 18FE0D84C406E6E4C4FD80F63C09370218FE0D84C40'::geometry)
> -[ RECORD 7
> QUERY PLAN | Filter: ((polygon &&
> C4FD80F63C0
> 000000207AF24C400708E6E8710963C0000000207AF24C400708E6E8710963C09370218F
> E0D84C406E6E4C4FD80F63C09370218FE0D84C40'::geometry) AND wi
> thin('0101000020E61000003A3B191CA50C63C0603DEE5BADE54C40'::geometry,
> polygon))
> -[ RECORD 8
> QUERY PLAN | Total runtime: 1.459 ms
> FOR STATE_SHAPES_2:
> explain analyze
> FROM states s, state_shapes_2 ss
> ss.polygon);
> -[ RECORD 1
> QUERY PLAN | Hash Join (cost=1.81..4.64 rows=1 width=165866) (actual
> time=61.708..61.762 rows=1 loops=1)
> -[ RECORD 2
> -[ RECORD 3
> width=21) (actual time=0.008..0.041 rows=60 loops=1)
> -[ RECORD 4
> QUERY PLAN | -> Hash (cost=1.79..1.79 rows=1 width=165861) (actual
> time=61.683..61.683 rows=1 loops=1)
> -[ RECORD 5
> QUERY PLAN | -> Seq Scan on state_shapes_2 ss (cost=0.00..1.79
> rows=1 width=165861) (actual time=59.926..61.673 rows=1 lo
> ops=1)
> -[ RECORD 6
> C4FD80F63C0
> polygon))
> -[ RECORD 7
> QUERY PLAN | Total runtime: 61.825 ms
> Why does the Multipolygon table NOT make use of the index?
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
