[postgis-devel] Gist index not used with Multipolygons
Chris Hodgson
chodgson at refractions.net
Thu Oct 11 18:04:37 PDT 2007
What Mark said is correct. If a large enough proportion of the
multi-polygons in the table are expected to overlap your query box
(based on the statistics for the table), then it is actually faster to
to a sequence scan than an index scan. If the number of multi-polygons
in the table is small enough, then it doesn't matter what query box you
give it, this will always be the case.
If you are still wondering why the second query is slower, if it is
using a supposedly faster method, then consider the fact that your
multi-polygons are larger and more complicated and thus take longer to
to test against each other.
Chris
