[postgis-devel] AsSVG patch
Paul Ramsey
pramsey at cleverelephant.ca
Thu Apr 10 07:39:52 PDT 2008
Marco,
Thanks, I'm sorry I should have e-mailed you when I applied the patch.
You'll find it's in the svn version, please check it for correctness.
P.
On Thu, Apr 10, 2008 at 1:30 AM, Marco Hugentobler
<marco.hugentobler at karto.baug.ethz.ch> wrote:
> Dear postgis developers,
> As I didn't receive any feedback to the patch for AsSVG, I just repeat my
> e-mail. I think the patch is quite interesting for svg power users and so it
> would be good if someone could review it and it could ev. find its way to the
> standard PostGIS distribution.
> Regards,
> Marco
> ---------- Weitergeleitete Nachricht ----------
> Betreff: [postgis-devel] AsSVG patch
> Datum: Freitag 08 Februar 2008
> Von: "Marco Hugentobler" <marco.hugentobler at karto.baug.ethz.ch>
> An: postgis-devel at postgis.refractions.net
> Find attached a patch that improves the svg output:
> * Support of GeometryCollection geometries
> * proper closing of the SVG path geometries using the SVG "z|Z" command (in
> case of POLYGON|MULTIPOLYGON elements)
> * introduction of additional white-spaces in some cases for easier parsing
> * removal of unnecessary minus signs infront of "0" coordinates
> The patch has been tested by the SVG experts Andreas Neumann, Klaus Förster
> and Bruce Rindahl. It would be great if the patch could be integrated into
> postgis svn. Please review the code carefully, as I'm a newbie in postgis
> server programming.
> The documentation of ST_AsSVG could be changed the following way:
> ST_AsSVG(geometry, [rel], [precision])
> Return the geometry as an SVG path data. Use 1 as second argument to have the
> path data implemented in terms of relative moves, the default (or 0) uses
> absolute moves. Third argument may be used to reduce the maximum number of
> decimal digits used in output (defaults to 15). Point geometries will be
> rendered as cx/cy when 'rel' arg is 0, x/y when 'rel' is 1. Multipoint
> geometries are delimited by commas (","), GeometryCollection geometries are
> delimited by semicolons (";").
> Best regards,
> Marco
> Dr. Marco Hugentobler
> Institute of Cartography
> ETH Zurich
> postgis-devel mailing list
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
