[postgis-devel] PostGIS Development Roadmap
Dane Springmeyer blake at hailmail.net
Tue Apr 22 11:40:52 PDT 2008
On Apr 21, 2008, at 9:52 PM, Kevin Neufeld wrote:
> These all sound good to me.  Can we add to this list a documentation
> overhaul?
> Personally, I would love to see the documentation become much more
> exhaustive in it's method descriptions (a more professional look
> wouldn't hurt either).
I agree. I'd add that function comments would be a useful thing as
well. It would be great to be able to call from within the psql
interpreter a nice concise usage example or explanation. Kind of like
docstrings in python.
I'd be happy to work on this little piece if anyone has suggestions
about the best approach.
For my own PostgreSQL usage I have wrapper functions that query the
function comments (these do exist for most standard PostgreSQL
functions), and build boilerplate usage text.
I will paste them below if any of you have comments on how to better
adapt them to PostGIS.
Cheers,
Dane
-- Helper function to find basic info about PostGIS functions
DROP function postgis_help(text);
CREATE or REPLACE function postgis_help(in text, out usage text, out
comments text)
RETURNS SETOF record AS $$
SELECT  DISTINCT proname||'('||oidvectortypes(proargtypes)||')' as
usage, obj_description(oid,'pg_proc') as comments FROM pg_proc WHERE
proname ilike '%' || $1 || '%';
$$ language SQL;
COMMENT on function postgis_help(in text) is $$A function to find the
usage of other functions. Hint: for all postgis functions that operate
on WKT type "select * from postgis_help('wkt');"$$;
--// Usage // --
--All WKT functions
--All postgis functions
select * from postgis_help(E'st\\_' )
--The query its own comment
select * from postgis_help('help');
-- Helper function to format PostGIS function info into more readable
strings
DROP function postgis_details(text);
CREATE or REPLACE function postgis_details(in text, out function text,
out details text, out comments text)
SELECT CASE
	WHEN proname = 'st_affine' and pronargs = 7 then 'st_affine(geometry,
6 floats)'
	WHEN proname = 'st_affine' and pronargs = 13 then
'st_affine(geometry, 12 floats)'
	WHEN proname = 'affine' and pronargs = 7 then 'affine(geometry, 6
floats)'
	WHEN proname = 'affine' and pronargs = 13 then 'affine(geometry, 12
floats)'
	ELSE replace((proname||'('||oidvectortypes(proargtypes)||')'),
'double precision', 'float')
END as function, CASE
	WHEN pronargs < 2 then 'Takes '|| pronargs || ' arg,'
	WHEN pronargs > 1 then 'Takes '|| pronargs || ' args,'
END ||  ' returns ' || CASE WHEN p.proretset THEN 'a set of ' ELSE ''
END || CASE
	WHEN proisagg = 'true' then 'an aggregate '
	WHEN proisagg = 'false' then ''
END|| CASE
	WHEN proname ilike '%kml%' then 'kml geometry'
	WHEN proname ilike '%svg%' then 'gml geometry'
	WHEN proname ilike '%gml%' then 'svg geometry'
	WHEN proname ilike '%ewkt%' then 'Postgis (3d) Well Known Text'
	WHEN proname ilike '%text%' then 'Well Known Text'
	WHEN pg_catalog.format_type(p.prorettype, NULL) = 'bytea' then
'binary string (bytea)'
	WHEN pg_catalog.format_type(p.prorettype, NULL) = 'integer' then 'an
integer'
	ELSE replace((pg_catalog.format_type(p.prorettype, NULL)), 'double
precision', 'a float')
END as Details,
FROM pg_proc as p WHERE proname ilike '%' || $1 || '%'  order by
proname;
$$ language SQL;
COMMENT on function postgis_details(in text) is $$A function to find
the usage of other functions. Hint: for all postgis functions that
perform affine operations type "select * from
postgis_details('affine');"$$;
--// Usage // --
select * from postgis_details('affine');
select * from postgis_details(E'st\\_' );
--All WKT functions
select * from postgis_details('wkt')
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20080422/710df9ff/attachment.html>
