[postgis-devel] Lame attempt at cascade union in sql
Paul Ramsey pramsey at cleverelephant.ca
Thu Aug 7 12:54:53 PDT 2008
Gods,
Your last test is a close approximation to the true cascaded union,
and that's 2 orders of magnitude faster than the naive approach.
P.
On Thu, Aug 7, 2008 at 12:46 PM, Kevin Neufeld <kneufeld at refractions.net> wrote:
> Hi Regina,
> So, I ran a few tests on a table with ~30000 overlapping polygons.
> Test1:
> SELECT ST_Union(the_geom) FROM sample_poly;
> --  Total runtime: + 2 hours before I cancelled it.
> Test2:
> SELECT ST_CascadeUnion(the_geom) FROM sample_poly;
> --  Total runtime: 19 minutes.
> Test3:
> SELECT ST_Union(the_geom) AS the_geom
> FROM (
>  SELECT min(id) AS id, ST_Union(the_geom) AS the_geom
>  FROM (
>    FROM (
>      FROM (
>        FROM sample_poly
>        GROUP BY round(id/10)
>        ORDER BY id) AS tmp1
>      GROUP BY round(id/100)
>      ORDER BY id) AS tmp2
>    GROUP BY round(id/1000)
>    ORDER BY id) AS tmp3
>  GROUP BY round(id/10000)
>  ORDER BY id) AS tmp4
> GROUP BY round(id/100000);
> --  Total runtime: 1.5 minutes
> Test4:
> Reordered the tuples in sample_poly by "ORDER BY
> ST_SnapToGrid(ST_Centroid(the_geom), 0.01);"
> Reran query in Test3:
> --  Total runtime: 50 secs
> So, your function is a definite improvement over ST_Union, but the timings
> could still be better.
> Cheers,
> Kevin
> Obe, Regina wrote:
>> Kevin,
>> Can you try the cascade approach I sent in my last email with your large
>> dataset.
>> I tried it with my real data and here are the results
>> --time 3328 ms, 3203 ms, 3188 ms
>> FROM (SELECT * FROM landparcels
>> WHERE pid lIKE '01%' and the_geom is not null
>> LIMIT 1000) p
>> --time 23375 ms, 23594 ms, 24109 ms
>> LIMIT 1000) p
>> The substance of this message, including any attachments, may be
>> confidential, legally privileged and/or exempt from disclosure
>> pursuant to Massachusetts law. It is intended
>> solely for the addressee. If you received this in error, please
>> contact the sender and delete the material from any computer.
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
