[postgis-devel] Issue 46 in postgis: server connexion closed unexpectedly using shortest_path
codesite-noreply at google.com
Wed Aug 13 01:46:31 PDT 2008
Issue 46: server connexion closed unexpectedly using shortest_path
http://code.google.com/p/postgis/issues/detail?id=46
New issue report by c_moh... at yahoo.fr:
What steps will reproduce the problem?
1. install the 3 dll librouting (see attached files) (I put them in the
folder postgreSQL\8.3\lib)
2. execute the file dijkstra.sql to create the function shortest_path
3. Restore the database "routingtest" (see attached files)
4. execute the query :
SELECT a.edge_id
FROM shortest_path('SELECT id, source, target, cost FROM
roads_europe_edges', 1, 3, false, false)
AS a
LEFT JOIN roads_europe ON vertex_id = gid ;
What is the expected output? What do you see instead?
What version of the product are you using? On what operating system?
I'm using pgAdmin III with postgres 8.3 and postgis 1.3.3 on windows XP
Please provide any additional information below.
Nouveau dossier (2).rar 2.4 MB
Issue attributes:
Status: New
Owner: ----
Labels: Type-Defect Priority-Medium
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
