[postgis-devel] Issue 46 in postgis: server connexion closed unexpectedly using shortest_path
codesite-noreply at google.com
Wed Aug 20 06:48:10 PDT 2008
Issue 46: server connexion closed unexpectedly using shortest_path
http://code.google.com/p/postgis/issues/detail?id=46
Comment #1 by mark.cav... at siriusit.co.uk:
Unfortunately the query above does not use PostGIS functions - you'll need
to report
this to the pgrouting people instead.
ATB,
Mark.
Issue attribute updates:
Status: WontFix
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
