[postgis-devel] postgis ST_AsEWKT and ArcSDE's ST_ type
DNC dncarreira at gmail.com
Thu Aug 14 04:58:56 PDT 2008
Hello.
I'm wondering if anyone can spot what's failing between ArcSDE's text
representation of a 3dm geometry column and what PostGIS expects. I'm
getting points from LINESTRING ZM in the following sql (shape is an ArcSDE
spatial type column, st_astext is an ArcSDE function and so is st_asbinary):
select objectid,st_astext(shape) AS SDE, ST_AsEWKT(st_asbinary(shape)) as PG
from gdbman.srega_adutores where objectid<=7400;
The output is like this (arranged for readability):
objectid=7356
SDE="LINESTRING ZM ( 268150.63700000 153514.32700000 0.00000000 1.#QNAN000,
268151.15900000 153513.31200000 0.00000000 1.#QNAN000, 268153.38500000
153513.50000000 0.00000000 1.#QNAN000, 268219.31400000 153519.58500000
0.00000000 1.#QNAN000, 268288.04400000 153525.98200000 0.00000000
1.#QNAN000, 268357.54700000 153532.72800000 0.00000000 1.#QNAN000)"
PG="POINT(-179.999999497086 17.2800119090087)"
objectid=7357
SDE="LINESTRING ZM ( 267722.96400000 153387.13900000 0.00000000 1.#QNAN000,
267723.71600000 153386.74100000 0.00000000 1.#QNAN000, 267726.41100000
153387.96400000 0.00000000 1.#QNAN000, 267744.05200000 153396.02100000
0.00000000 1.#QNAN000, 267747.68000000 153397.76500000 0.00000000
1.#QNAN000, 267751.34800000 153399.71700000 0.00000000 1.#QNAN000,
267755.24200000 153402.00900000 0.00000000 1.#QNAN000, 267758.85400000
153404.35600000 0.00000000 1.#QNAN000, 267789.22500000 153424.94200000
0.00000000 1.#QNAN000, 267848.41000000 153465.14800000 0.00000000
1.#QNAN000, 267855.75200000 153470.07200000 0.00000000 1.#QNAN000,
267858.00700000 153471.49900000 0.00000000 1.#QNAN000, 267860.58700000
153472.93500000 0.00000000 1.#QNAN000, 267862.94300000 153474.07800000
0.00000000 1.#QNAN000, 267885.27100000 153483.79100000 0.00000000
1.#QNAN000, 267891.50100000 153486.25400000 0.00000000 1.#QNAN000,
267897.54700000 153488.19700000 0.00000000 1.#QNAN000, 267903.28200000
153489.61300000 0.00000000 1.#QNAN000)"
PG="POINT(-179.999998491257 128.160017917157)"
Is there anyway to build a geometry from this?
Thanks,
Duarte Carreira
View this message in context: http://www.nabble.com/postgis-ST_AsEWKT-and-ArcSDE%27s-ST_-type-tp18980146p18980146.html
Sent from the PostGIS - Dev mailing list archive at Nabble.com.
