[postgis-devel] Issue 37 in postgis: ST_Intersection throws error on postgis Linux installation
codesite-noreply at google.com codesite-noreply at google.com
Thu Aug 14 16:39:03 PDT 2008
Issue 37: ST_Intersection throws error on postgis Linux installation
http://code.google.com/p/postgis/issues/detail?id=37
Comment #4 by mtnclimb:
In order to ensure that operations are carried out robustly, sometimes the
engine
adjusts input geometries slightly.  This would explain the difference in
output.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
