[postgis-devel] WKB conversion
Obe, Regina
robe.dnd at cityofboston.gov
Thu Aug 28 14:42:34 PDT 2008
Possibly dumb question. In inspecting the postgis code base. I am noticing a few functions restated one
version for if WKB_CONVERSION and one for If not. For example I was looking at the PostGIS2GEOS functions to try to understand what exactly those do when I came across these fraternal twins.
Looking thru the code base, I can't see where WKB_CONVERSION is ever set or if this is just a hold-over from prior times.
Thanks,
Regina
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20080828/1a354ba8/attachment.html>
