[postgis-devel] Issue 34 in postgis: .prj creation by pgsql2shp
codesite-noreply at google.com codesite-noreply at google.com
Tue Dec 2 08:47:36 PST 2008
Comment #3 on issue 34 by ke... at refractions.net: .prj creation by pgsql2shp
http://code.google.com/p/postgis/issues/detail?id=34
I think that's a good call.  Having a flag to specify the SRID would get
confused
with optionally wanting to transform the table/query to a new projection on
the way
out (which actually wouldn't be a bad option to have).
Looking forward to it.
-- Kevin
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
