[postgis-devel] Issue 74 in postgis: AddGeometryColumn does not detect search_path properly
codesite-noreply at google.com codesite-noreply at google.com
Tue Dec 2 13:04:21 PST 2008
Updates:
	Labels: -Type-Patch Type-Defect
Comment #6 on issue 74 by robe.... at cityofboston.gov: AddGeometryColumn does
http://code.google.com/p/postgis/issues/detail?id=74
It does when I test it under 1.3.4 (though don't have my 1.4 around to test
with).
Though I always questioned if that was correct behavior.
Example -- SELECT ST_GeometryType('POINT(1 2)')
returns
ST_Point
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
