[postgis-devel] Issue 74 in postgis: AddGeometryColumn does not detect search_path properly
codesite-noreply at google.com
Tue Dec 2 13:11:24 PST 2008
Comment #7 on issue 74 by ke... at refractions.net: AddGeometryColumn does not
http://code.google.com/p/postgis/issues/detail?id=74
Umm. Yup, you're correct, I misread my skim read of the function ... missed
the
concatenation at the end of the function.
In any case, I agree that this is not correct behaviour as it does not
follow the specs.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
