[postgis-devel] Issue 34 in postgis: .prj creation by pgsql2shp
codesite-noreply at google.com codesite-noreply at google.com
Wed Dec 3 09:28:43 PST 2008
Comment #5 on issue 34 by mark.cav... at siriusit.co.uk: .prj creation by
pgsql2shp
http://code.google.com/p/postgis/issues/detail?id=34
My vote is output the .prj automatically (unless the column is NULL, in
which case
don't output it); then once it is there, the user can alter to taste. Bear
in mind
that the current behaviour for pgsql2shp is that if there is already a
shapefile with
the same name in the current directory, it will simply be overwritten - so
it makes
sense to keep the behaviour the same.
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
