[postgis-devel] Issue 34 in postgis: .prj creation by pgsql2shp
codesite-noreply at google.com
Wed Dec 3 10:46:17 PST 2008
Updates:
Owner: robe.... at cityofboston.gov
Comment #6 on issue 34 by robe.... at cityofboston.gov: .prj creation by
pgsql2shp
http://code.google.com/p/postgis/issues/detail?id=34
Attached is my revised patch. For now I am just outputting proj file if it
can be
output. I also took some of your recommendations - e.g. I think fixing
buffer
overflow possibility and Kevin's checking geometry_columns first to save
time.
Though I have to admit my SQL you may find unconventional and you may
disapprove, but
does seem to short-circuit correctly with a 1,000,000 record table set I
tried.
Check it out.
It was the only way I could think of checking without doing 2 separate
database calls
which I hated the thought of more. Also I'm not escaping the table and
column names
-- how do you do that in C? What do we do in cases where there are null
geometries --
I'm just taking the first srid if it has null and one srid. Actually I'm
not even
sure pgsql2shp handles that correctly now since I think I have had weird
row shifts
when outputting nulls in the past.
Also now I am checking the geometry_columns table -- hmm getting the schema
right is
now somewhat important. So I would like use the table visible thing and
just pull
the schema from pg when its not given.
pgsql2shp081203.patch 5.3 KB
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
