[postgis-devel] Code repository
    Obe, Regina
    robe.dnd at cityofboston.gov
    Thu Dec  4 21:34:28 PST 2008
Kevin's comment about geometry cleaning got me thinking.  There are a lot of very useful user code contributions e.g that minimum bounding circle, cleaning functions and so forth. PL/R group has similar issues and the topic came up recently on that list too.
The Wiki doesn't quite seem like the ideal place to store those things ( unless there is a plugin I don't know about) ,(though a reference from there makes sense or an api xml call from a service).  Wiki is not ideal because first it mangles my plpgsql code so a pain to put in and then when you copy its hard to get out those ? marks.  Second its not easy to search by concept etc.
I was thinking of something like http://snipplr.com  and I think there are about 5 or so like it as an ideal interface.
The nice thing about snipplr and other like things is - well it color-codes, easy to get code in and out, and they have an xml-rpc interface that makes it easy to tie into many editors (for example I have that in my programming editor so copy code is a key press away).
The interface is what I like most.  As to whether we use a free service or setup our own, I'm more or less indifferent to.
If we setup our own (is that even possible?) would be nice to share with PL/R folks too since there is a lot of overlap between PostGIS and PL/R usage.
Just food for thought.
Regina
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20081205/bd23f7d0/attachment.html>
