[postgis-devel] CLUSTER in 8.3
Paul Ramsey
pramsey at cleverelephant.ca
Thu Dec 4 21:36:02 PST 2008
I just confirmed this happening under PostGIS 1.3.4 also...
P
On Thu, Dec 4, 2008 at 9:35 PM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> You clustered ttt then you counted all_counties...
> P
> On Thu, Dec 4, 2008 at 8:44 PM, Obe, Regina <robe.dnd at cityofboston.gov> wrote:
>> I tried your test on my all_counties table and it worked fine. But I was
>> doing it from pgadmin III. and I have left out that clusture thing you
>> were doing. What does that do? :)
>> create table ttt as select * from all_counties;
>> create index ttt_gix on ttt using gist(the_geom);
>> cluster ttt using ttt_gix;
>> select count(*) from all_counties;
>> -- gives me 3141 records --
>> I guess we must have similar county tables since we have the same record
>> count.
>> My projection is in 3395.
>> running
>> "PostgreSQL 8.3.5 on i686-redhat-linux-gnu, compiled by GCC gcc (GCC) 4.1.2
>> 20071124 (Red Hat 4.1.2-42)"
>> "POSTGIS="1.3.4" GEOS="3.0.3-CAPI-1.4.2" PROJ="Rel. 4.5.0, 22 Oct 2006"
>> USE_STATS"
>> Hope that helps,
>> Regina
>> -----Original Message-----
>> From: postgis-devel-bounces at postgis.refractions.net on behalf of Paul Ramsey
>> Sent: Thu 12/4/2008 3:37 PM
>> To: PostGIS Development Discussion
>> Subject: Re: [postgis-devel] CLUSTER in 8.3
>> Maybe I'm doing something wrong... here's a log of how I exercised this:
>> pramsey=# create table ttt as select * from counties;
>> SELECT
>> pramsey=# create index ttt_gix on ttt using gist(the_geom);
>> CREATE INDEX
>> pramsey=# clusture
>> pramsey=# select count(*) from ttt;
>> count
>> 3141
>> (1 row)
>> pramsey=# cluster ttt using ttt_gix;
>> CLUSTER
>> count
>> 0
>> (1 row)
>> pramsey=# select version();
>> version
>> PostgreSQL 8.3.5 on i386-apple-darwin9.5.0, compiled by GCC
>> i686-apple-darwin9-gcc-4.0.1 (GCC) 4.0.1 (Apple Inc. build 5465)
>> (1 row)
>> pramsey=# select postgis_full_version();
>> POSTGIS="1.3.4SVN" GEOS="3.1.0-CAPI-1.5.0" PROJ="Rel. 4.6.0, 21 Dec
>> 2007" USE_STATS
>> (1 row)
>> pramsey=#
>> On Wed, Dec 3, 2008 at 8:43 AM, Kevin Neufeld <kneufeld at refractions.net>
>> wrote:
>>> Is seems fine (for Points anyway) on my 8.3.3 install running on an old
>>> FC3
>>> box.
>>> Did you run out of disk space? Did the transaction get half way through
>>> and
>>> was forced to stop?
>>> -- Kevin
>>> Paul Ramsey wrote:
>>>> Is it just me, or has clustering on spatial indexes stopped working in
>>>> 8.3? First, the syntax of CLUSTER has been changed, from "CLUSTER
>>>> [index] ON [table]" to "CLUSTER [table] USING [index]". Second, when I
>>>> run the new syntax using a gist index as the target, the index
>>>> disappears and all row count drops to zero!
>>>> P.
>>>> _______________________________________________
>>>> postgis-devel mailing list
>>>> postgis-devel at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
>> The substance of this message, including any attachments, may be
>> confidential, legally privileged and/or exempt from disclosure pursuant to
>> Massachusetts law. It is intended solely for the addressee. If you received
>> this in error, please contact the sender and delete the material from any
>> computer.
>> Help make the earth a greener place. If at all possible resist printing this
>> email and join us in saving paper.
