[postgis-devel] CLUSTER in 8.3
Paul Ramsey pramsey at cleverelephant.ca
Thu Dec 4 21:42:27 PST 2008
And everything works hunky dory with postgis 1.4.0 and pgsql 8.2.11...
On Thu, Dec 4, 2008 at 9:36 PM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> I just confirmed this happening under PostGIS 1.3.4 also...
> P
> On Thu, Dec 4, 2008 at 9:35 PM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
>> You clustered ttt then you counted all_counties...
>> P
>> On Thu, Dec 4, 2008 at 8:44 PM, Obe, Regina <robe.dnd at cityofboston.gov> wrote:
>>> I tried your test on my all_counties table and it worked fine.  But I was
>>> doing it from pgadmin III.  and I have left out that  clusture thing you
>>> were doing.  What does that do? :)
>>> create table ttt as select * from all_counties;
>>> create index ttt_gix on ttt using gist(the_geom);
>>> cluster ttt using ttt_gix;
>>> select count(*) from all_counties;
>>> -- gives me 3141 records --
>>> I guess we must have similar county tables since we have the same record
>>> count.
>>> My projection is in 3395.
>>> running
>>> "PostgreSQL 8.3.5 on i686-redhat-linux-gnu, compiled by GCC gcc (GCC) 4.1.2
>>> 20071124 (Red Hat 4.1.2-42)"
>>> "POSTGIS="1.3.4" GEOS="3.0.3-CAPI-1.4.2" PROJ="Rel. 4.5.0, 22 Oct 2006"
>>> USE_STATS"
>>> Hope that helps,
>>> Regina
>>> -----Original Message-----
>>> From: postgis-devel-bounces at postgis.refractions.net on behalf of Paul Ramsey
>>> Sent: Thu 12/4/2008 3:37 PM
>>> To: PostGIS Development Discussion
>>> Subject: Re: [postgis-devel] CLUSTER in 8.3
>>> Maybe I'm doing something wrong... here's a log of how I exercised this:
>>> pramsey=# create table ttt as select * from counties;
>>> SELECT
>>> pramsey=# create index ttt_gix on ttt using gist(the_geom);
>>> CREATE INDEX
>>> pramsey=# clusture
>>> pramsey=# select count(*) from ttt;
>>>  count
>>>   3141
>>> (1 row)
>>> pramsey=# cluster ttt using ttt_gix;
>>> CLUSTER
>>>  count
>>>      0
>>> (1 row)
>>> pramsey=# select version();
>>>                                                            version
>>>  PostgreSQL 8.3.5 on i386-apple-darwin9.5.0, compiled by GCC
>>> i686-apple-darwin9-gcc-4.0.1 (GCC) 4.0.1 (Apple Inc. build 5465)
>>> (1 row)
>>> pramsey=# select postgis_full_version();
>>>  POSTGIS="1.3.4SVN" GEOS="3.1.0-CAPI-1.5.0" PROJ="Rel. 4.6.0, 21 Dec
>>> 2007" USE_STATS
>>> (1 row)
>>> pramsey=#
>>> On Wed, Dec 3, 2008 at 8:43 AM, Kevin Neufeld <kneufeld at refractions.net>
>>> wrote:
>>>> Is seems fine (for Points anyway) on my 8.3.3 install running on an old
>>>> FC3
>>>> box.
>>>> Did you run out of disk space?  Did the transaction get half way through
>>>> and
>>>> was forced to stop?
>>>> -- Kevin
>>>> Paul Ramsey wrote:
>>>>> Is it just me, or has clustering on spatial indexes stopped working in
>>>>> 8.3? First, the syntax of CLUSTER has been changed, from "CLUSTER
>>>>> [index] ON [table]" to "CLUSTER [table] USING [index]". Second, when I
>>>>> run the new syntax using a gist index as the target, the index
>>>>> disappears and all row count drops to zero!
>>>>> P.
>>>>> _______________________________________________
>>>>> postgis-devel mailing list
>>>>> postgis-devel at postgis.refractions.net
>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
>>> The substance of this message, including any attachments, may be
>>> confidential, legally privileged and/or exempt from disclosure pursuant to
>>> Massachusetts law. It is intended solely for the addressee. If you received
>>> this in error, please contact the sender and delete the material from any
>>> computer.
>>> Help make the earth a greener place. If at all possible resist printing this
>>> email and join us in saving paper.
