[postgis-devel] Issue 80 in postgis: ST_Multi seg faults
codesite-noreply at google.com
Fri Dec 5 00:10:29 PST 2008
Comment #2 on issue 80 by robe.... at cityofboston.gov: ST_Multi seg faults
http://code.google.com/p/postgis/issues/detail?id=80
I think I found the smoking gun. Shouldn't lwgeom_contains_subgeoms have a
line for
MULTILINETYPE? -- take a look at lwgeom_dump.c around line 56.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
