[postgis-devel] Issue 80 in postgis: ST_Multi seg faults
codesite-noreply at google.com
Fri Dec 5 04:39:15 PST 2008
Comment #3 on issue 80 by mark.cav... at siriusit.co.uk: ST_Multi seg faults
http://code.google.com/p/postgis/issues/detail?id=80
Good spot Regina! For some reason, this doesn't segfault on my machine but
just
returns a slightly wrong answer?! Anyway, the fix looks good.
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
