[postgis-devel] Issue 80 in postgis: ST_Multi seg faults
codesite-noreply at google.com
Fri Dec 5 04:43:15 PST 2008
Updates:
Status: Testing
Comment #4 on issue 80 by robe.... at cityofboston.gov: ST_Multi seg faults
http://code.google.com/p/postgis/issues/detail?id=80
I tested the patch on 1.3 but I'm still getting my system back to 1.4 so
haven't
tested the 1.4 patch. If you can confirm the 1.4 patch works, that will be
great.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
