[postgis-devel] Re: [HACKERS] CLUSTER in 8.3.5 on GIST indexes loses all rows
Paul Ramsey
pramsey at cleverelephant.ca
Fri Dec 5 12:15:06 PST 2008
FYI, this is not limited to PostGIS GIST, it appears to be all GIST
(gid is an integer column and I have loaded btree_gist):
pramsey=# create table ttt as select * from counties;
SELECT
pramsey=# create index gid_bix on ttt using gist (gid);
CREATE INDEX
pramsey=# select count(*) from ttt;
count
3141
(1 row)
pramsey=# cluster ttt using gid_bix;
CLUSTER
count
0
(1 row)
pramsey=# select version();
version
PostgreSQL 8.3.5 on i386-apple-darwin9.5.0, compiled by GCC
i686-apple-darwin9-gcc-4.0.1 (GCC) 4.0.1 (Apple Inc. build 5465)
(1 row)
On Fri, Dec 5, 2008 at 6:05 AM, Gregory Stark <stark at enterprisedb.com> wrote:
> Mark Cave-Ayland <mark.cave-ayland at siriusit.co.uk> writes:
>> So in other words, the contents of the temporary table has just disappeared :(
> Uhm. That rather sucks. I was able to reproduce it too.
> It seems to happen after I pause for a bit, and not when I run the script in
> fast succession.
> Gregory Stark
> EnterpriseDB http://www.enterprisedb.com
> Ask me about EnterpriseDB's Slony Replication support!
> Sent via pgsql-hackers mailing list (pgsql-hackers at postgresql.org)
> To make changes to your subscription:
> http://www.postgresql.org/mailpref/pgsql-hackers
