[postgis-devel] Issue 81 in postgis: This geometry causes buffer(?, 0) to crash the PostGresql server
codesite-noreply at google.com codesite-noreply at google.com
Fri Dec 5 15:19:58 PST 2008
Status: New
Owner: ----
New issue 81 by dstahlke: This geometry causes buffer(?, 0) to crash the
PostGresql server
http://code.google.com/p/postgis/issues/detail?id=81
What steps will reproduce the problem?
1. Run the attached script
2.
3.
What is the expected output? What do you see instead?
server closed the connection unexpectedly
	This probably means the server terminated abnormally
	before or while processing the request.
connection to server was lost
What version of the product are you using? On what operating system?
psql 8.3.5
postgis_version: 1.3 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
postgis_geos_version: 3.0.1-CAPI-1.4.2
Fedora 10
Please provide any additional information below.
The following is written to the log file:
bufferOriginalPrecision failed (TopologyException: unable to assign hole to
a shell), trying with reduced precision
recomputing with precision scale factor = 1e+09
Scaler: offsetX,Y: 0,0 scaleFactor: 1e+09
  dstahlke svdev [local] SELECT:
../../source/headers/geos/noding/SegmentString.h:175: void
geos::noding::SegmentString::testInvariant() const: Assertion `pts->size()
> 1' failed.
LOG:  server process (PID 863) was terminated by signal 6: Aborted
LOG:  terminating any other active server processes
LOG:  all server processes terminated; reinitializing
LOG:  database system was interrupted; last known up at 2008-12-05 14:16:19
AKST
LOG:  database system was not properly shut down; automatic recovery in
progress
LOG:  record with zero length at 0/3C5BC340
LOG:  redo is not required
LOG:  database system is ready to accept connections
LOG:  autovacuum launcher started
	geos-bug.sql  13.5 KB
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
