[postgis-devel] RE: [BUGS] BUG #4567: Clustering on GIST INDEX clobbers records in table intermittently
Obe, Regina
robe.dnd at cityofboston.gov
Sun Dec 7 23:51:09 PST 2008
"Regina Obe" <robe.dnd at cityofboston.gov> writes:
> Description: Clustering on GIST INDEX clobbers records in table
> intermittently
> This doesn't always happen to me but does intermittently, and for others it
> happens all the time.
> I wonder whether this is fixed by this recent patch:
> http://archives.postgresql.org/pgsql-committers/2008-12/msg00053.php
> The pre-patch behavior would've depended on the value of a
> never-initialized struct field, so the erratic behavior is explained
> by varying contents of memory. I'm unable to make it happen in an
> assert-enabled build, but that's probably because the initial contents
> of a palloc'd chunk are never zeroes in such a build.
> regards, tom lane
Tom,
Thanks for the quick response on this.
Paul,
You think by chance you can test out the patch since you can make this bug happen consistently on your build.
Thanks,
Regina
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20081208/04367e89/attachment.html>
