[postgis-devel] RE: [BUGS] BUG #4567: Clustering on GIST INDEX clobbers records in table intermittently
Paul Ramsey
pramsey at cleverelephant.ca
Mon Dec 8 11:02:08 PST 2008
Yes, that patch removes the bug.
P.
On Sun, Dec 7, 2008 at 11:51 PM, Obe, Regina <robe.dnd at cityofboston.gov> wrote:
> "Regina Obe" <robe.dnd at cityofboston.gov> writes:
>> Description: Clustering on GIST INDEX clobbers records in table
>> intermittently
>> This doesn't always happen to me but does intermittently, and for others
>> it
>> happens all the time.
>> I wonder whether this is fixed by this recent patch:
>> http://archives.postgresql.org/pgsql-committers/2008-12/msg00053.php
>> The pre-patch behavior would've depended on the value of a
>> never-initialized struct field, so the erratic behavior is explained
>> by varying contents of memory. I'm unable to make it happen in an
>> assert-enabled build, but that's probably because the initial contents
>> of a palloc'd chunk are never zeroes in such a build.
>> regards, tom lane
> Tom,
> Thanks for the quick response on this.
> Paul,
> You think by chance you can test out the patch since you can make this bug
> happen consistently on your build.
> Thanks,
> Regina
> ________________________________
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure pursuant to
> Massachusetts law. It is intended solely for the addressee. If you received
> this in error, please contact the sender and delete the material from any
> computer.
> Help make the earth a greener place. If at all possible resist printing this
> email and join us in saving paper.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
