[postgis-devel] Re: [postgis-users] Changed bahaviour ofPostGISconfuses MapServer
Obe, Regina
robe.dnd at cityofboston.gov
Sat Dec 13 12:37:38 PST 2008
+1
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net on behalf of Paul Ramsey
Sent: Sat 12/13/2008 3:02 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] Re: [postgis-users] Changed bahaviour ofPostGISconfuses MapServer
Fair enough. Then I would like to change the PostGIS downloads page to
reference 1.3.3 in the interim... P.
On Sat, Dec 13, 2008 at 11:46 AM, Obe, Regina <robe.dnd at cityofboston.gov> wrote:
> -1
> Well I mean not ASAP. Lets wait till at least Tuesday. I agree it is a
> far reaching bug that I suspect affects many functions. Anything that needs
> to extract a multi into individual linestrings will be affected.
> Then again I'm not convinced that many people have deployed into production
> and this to me would affect people who are unable to compile for themselves
> more than anyone else (e.g lots of windows users who have deployed) so we
> have to wait for Mark's +1 anyway.
> Besides I want to get the torture script further along to brute force test
> to make sure no other surprises. So far the torture script
> tests all the functions that deal with one geometry, or 2 geometry or no
> args, but have yet to test for things that take other arguments (like all
> the Affine and so forth).
> Sent: Sat 12/13/2008 12:13 PM
> To: PostGIS Users Discussion; PostGIS Development Discussion
> Subject: [postgis-devel] Re: [postgis-users] Changed bahaviour of
> Yes, Peter, I think it should call for a quick 1.3.5. Mapserver users
> are a huge contingent of PostGIS users, and anyone with a LINE layer
> now has a crasher. 1.3.5 should come off the line ASAP. There's always
> more version numbers, IMO.
> Can we have a quick vote on 1.3.5 release-from-branch, no-waities?
> +1
> P.
> On Sat, Dec 13, 2008 at 1:25 AM, Peter Hopfgartner
> <peter.hopfgartner at r3-gis.com> wrote:
>> Mark Cave-Ayland wrote:
>>> Peter Hopfgartner wrote:
>>>> Dear MLs,
>>>> sorry for cross-posting to both, PostGIS and MS, but seems to rtouch
>>>> both.
>>>> I've tried to install PostGIS 1.3.4 on a CentOS 5 server with MapServer
>>>> 5.2.1 and PostgreSQL 8.2.11.
>>>> the command:
>>>> shp2img -l prova -e 1587541 5116731 1591730 5120008 -m prova.map >
>>>> ../../public/technet/test-<pgis-version>.png
>>>> with 1.3.3 gave the result shown in figure test-postgis-1.3.3-4.png (a
>>>> simple line layer)
>>>> Upgrading to 1.3.4 the picture became as in test-postgis-1.3.4-1.png, an
>>>> empty picture.
>>>> The relevant mapfile fragment is Mapfile.frag.txt, the SQL table
>>>> definition is e405.sql, all objects are MULTILINESTRINGs [SELECT
>>>> DISTINCT
>>>> geometrytype(the_geom) FROM public.e405 results in MULTILINESTRING], the
>>>> geometry column is registered as MULTILINESTRING in geometry_columns.
>>>> Running the MapServer query:
>>>> SELECT
>>>> asbinary(force_collection(force_2d(the_geom)),'NDR'),common_uid::text
>>>> from
>>>> public.e405 WHERE (tiplinapp is not null) and (the_geom && setSRID(
>>>> 'BOX3D(1587541 5116702.44897959,1591730
>>>> 5120036.55102041)'::BOX3D,find_srid('','public.e405','the_geom') ))
>>>> changed for better result readability into:
>>>> SELECT AsEWKT(force_collection(force_2d(the_geom))),common_uid::text
>>>> from
>>>> by hand gives slightly different results, as shown in the attached
>>>> files.
>>>> To make a long story short, 1.3.4 seems to better preserve the
>>>> MULTILINESTRING, but this seems to confuse MapServer.
>>>> Regards,
>>>> Peter
>>> Hi Peter,
>>> This is likely the known issue with MULTILINESTRINGs in 1.3.4 causing
>>> segfaults :( The patch you need is very simple and can be found here:
>>> http://postgis.refractions.net/pipermail/postgis-commits/2008-December/000866.html
>>> if you can't wait for a 1.3.5 release. Please let us know whether this
>>> resolves the problem for you.
>>> HTH,
>>> Mark.
>> Should this issue call for a quick 1.3.5 release? If I understood this
>> issue
>> well, everybody rendering PostGIS data stored as a MULTILINE geometry will
>> have this very same problem, at least with MapServer. I would guess that
>> this is quite a big share of PostGIS users that will be hit by this issue.
>> Regards,
>> Peter
>> Dott. Peter Hopfgartner
>> R3 GIS Srl - GmbH
>> Via Johann Kravogl-Str. 2
>> I-39012 Meran/Merano (BZ)
>> Email: peter.hopfgartner at r3-gis.com
>> Tel. : +39 0473 494949
>> Fax : +39 0473 069902
>> www : http://www.r3-gis.com
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure pursuant to
> Massachusetts law. It is intended solely for the addressee. If you received
> this in error, please contact the sender and delete the material from any
> computer.
> Help make the earth a greener place. If at all possible resist printing this
> email and join us in saving paper.
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20081213/79ba0684/attachment.html>
