[postgis-devel] 1.3.5SVN Fails the torture test
Obe, Regina robe.dnd at cityofboston.gov
Sat Dec 13 18:01:03 PST 2008
I added to the torture xsl script simple create table/add geometry column/drop geometry column/drop table for each garden geom and 1.3.5 SVN failed miserably.
I thought maybe it was a typo in my statement so I verified against my 1.3.4 and 1.3.3 installs and that part worked fine.
ERROR:  AddGeometryColumns() - invalid SRID
CONTEXT:  SQL statement "SELECT AddGeometryColumn('','', $1 , $2 , $3 , $4 , $5 )"
Can you guys test this snippet to make sure its not my 1.3.5SVN install.  I had pulled from nightly tar.
SELECT 'create,insert,drop Test: Start Testing Multi/POINT';
BEGIN;
	CREATE TABLE pgis_garden (gid serial);
	SELECT AddGeometryColumn('pgis_garden','the_geom',ST_SRID(the_geom),GeometryType(the_geom),ST_CoordDim(the_geom))
			FROM ((SELECT ST_SetSRID(ST_Point(i,j),4326) As the_geom
		FROM generate_series(-10,50,10) As i
			CROSS JOIN generate_series(40,70, 10) j)) As foo limit 1;
	SELECT AddGeometryColumn('pgis_garden','the_geom_multi',ST_SRID(the_geom),GeometryType(ST_Multi(the_geom)),ST_CoordDim(the_geom))
	INSERT INTO pgis_garden(the_geom, the_geom_multi)
	SELECT the_geom, ST_Multi(the_geom)
			CROSS JOIN generate_series(40,70, 10) j)) As foo;
	SELECT DropGeometryColumn ('pgis_garden','the_geom');
	SELECT DropGeometryTable ('pgis_garden');
COMMIT;
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20081213/deb2b62f/attachment.html>
