[postgis-devel] Some sort of memory leak?
Obe, Regina
robe.dnd at cityofboston.gov
Mon Dec 15 04:27:13 PST 2008
This one I'm not quite sure how to describe as a bug but it seems to be
a long standing problem (happens on my 1.3.3 install so certainly
nothing we should rush to fix).
Haven't tested on 1.4
This works --
SELECT ST_AsEWKT(ST_LineToCurve(ST_Buffer(ST_Point(i,j), j))) As
the_geom
FROM generate_series(-10,50,10) As i
CROSS JOIN generate_series(40,70, 20) As j
This works --
SELECT ST_Collect(ST_LineToCurve(ST_Buffer(ST_Point(i,j), j))) As
the_geom
But this crashes server sometimes (not all the time).
the_geom
This most often crashes but doesn't seem to on fresh restart
SELECT ST_AsEWKT(ST_Collect(the_geom)),
ST_AsEWKT(ST_Collect(ST_Multi(the_geom)))
FROM ((SELECT ST_LineToCurve(ST_Buffer(ST_Point(i,j),
j)) As the_geom
CROSS JOIN generate_series(40,70, 20) As j)) As
foo;
In case anyone is interested, attached is the latest torture script
compressed.
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
Type: application/x-zip-compressed
Desc: torturetest.zip
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20081215/88f4c97f/attachment.bin>
