[postgis-devel] Some sort of memory leak?
Obe, Regina
robe.dnd at cityofboston.gov
Mon Dec 15 05:07:05 PST 2008
Okay I guess there are still quite a few crashers in the curve support
section, so I took those tests out.
Attached is torture test minus the circular tests and minus the new
functions (ST_IsValidReason, ST_Populate_Geometry_Columns)
+1 for me as far as releasing a 1.3.5 assuming no one runs into any
crashes doing the above.
or notices anything questionable in the output.
Thanks,
Regina
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
Type: application/x-zip-compressed
Desc: torturetest35.zip
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20081215/38b9f033/attachment.bin>
